recently replace heater core / now cooling problem
1993 100 CS. i just replaced the heater core and things went well. i then added coolant and bled the air out of the system using the bleeder valve at the back of the engine. however, the car is over heating so i must of missed something. i try to bleed more air from the system and i still have a problem. is there another bleed valve somewhere? this is what happens.
car heats up to operating temperature fine. it then moves into the position near the first "dot" on the themp gauge. then the cooling system makes a thumping noise and the cooling hose from the coolant tank shakes like hell. is this the thermostat that i hear? it is obvious that the system is not flowing properly and therefore not cooling. what have i missed?
thank you for the help
Bleeding system
Definitely sounds like there is some remaining air in there somewhere. Cool VW guys refer to this as "vapor lock" Which has to do with the increase in pressure, throwing off the thermostat, making it not function properly when it should after heating up to normal operating temperatures. Try that other bleeder valve and see how it goes from there. And be sure not to break it. I ended up having to spend that $50 and waiting a week, for something that I could have easily avoided.
redrubberband88
02-08-2018 07:24 AM
redrubberband88
01-19-2018 01:32 AM
