what to do about timing belt?
Old 04-09-2009, 06:06 PM
New Member
rapid paw's Avatar
Default what to do about timing belt?
Hi, I have a 1997 A6 avant that has 120,000 miles. I need to replace the timing belt / water pump, right? Do I need to take it to the dealer, or can I do it myself? (I'm a pretty good mechanic, have most all the tools etc.) About how much should it cost, do I need any special tools? Also I'm having trouble finding a repair manual. Any info or advice would be a great help. THANKS
Old 04-09-2009, 08:57 PM
Zeitgeist 13's Avatar
I replaced a leaky thermostat on the green car a couple years ago, and found that you need the tool that holds the cam sprockets in place, as well the the one that locks the crankshaft. Other than those two, I don't remember anything unusual. In fact, 'cause there's so much room to work in that engine compartment, I thought it was quite easy.
Old 04-10-2009, 11:40 PM
A6Gary's Avatar
Its a fairly easy DIY job to do the TB maintenance. Just use the two special tools (#3242 and #3243) to ensure that you set the camshaft timimg correctly. SFTAs and you'll find lots of info
Old 04-16-2009, 05:49 PM
a6hcw's Avatar
You can get the Bentley Audi shop manual CD from
http://www.motorbookguy.com .
You may get a timing belt kit and tool rental from
www.blaupartsw.com .
Old 04-16-2009, 05:50 PM
a6hcw's Avatar
That is www.blauparts.com
12vA90
12v V6 Discussion
12
08-21-2007 05:37 AM
audiqtNewb
12
02-17-2007 08:42 AM
Michael Benno
19
09-04-2003 12:38 PM
banderson
Audi 100 / A6 (C4 Platform)
10
01-23-2002 11:55 AM
Darrell
08-03-2001 08:12 PM
Quick Reply: what to do about timing belt?
