New owner of 100 CS questions (round 2)
Old 10-20-2014, 09:51 AM
John Hopkins's Avatar
Default New owner of 100 CS questions (round 2)
I've been working through a lot of the little things that don't work on this wagon. I'm down to just a few now.
  1. Sunroof controls do nothing
  2. Cruise Control does nothing
  3. All of the interior lights but the driver's floor do not work
I've checked the fuses in the cabin and all are good.
Any ideas?
Old 10-20-2014, 11:22 AM
marcogyver's Avatar
1. On my A6 if I hold the key turned to the lock position the windows and roof will close, does the 100 do the same? I was thinking if you crank the sunroof open a little and use the key to close to verify if the motor and electronics are good.
2. Cruise control, think a common fault was vacuum lines in the engine compartment but check out this <A HREF="http://forums.quattroworld.com/s4s6/msgs/211949.phtml">LINK</A> for additional issues.
3. The drivers foot light should is controlled the same as passanger foot. Does that come on?
Old 10-20-2014, 04:06 PM
1) No, I think the sunroof on these is JUST the control on the roof.
2) I'll check that out. Thanks.
3) I need to check out the bulbs in the car, but I can't imagine that ALL but one of the interior bulbs are out.
Old 10-23-2014, 04:19 PM
marcogyver's Avatar
According to diagram the 2 front footwell and 1 dome light are pretty much tied together but share a couple of contact points. Does the dome turn on with the switch to constant on but not with the door? The lighted vanity mirrors use the same 12V but different grounds, do they work?
Old 10-23-2014, 05:10 PM
Actually, the passenger vanity light does work. None of the others with override switched do anything at any switch position though.
Old 10-24-2014, 12:21 PM
marcogyver's Avatar
The center dome light when switched to constant on takes power (12V and Ground) from the black connector at connector station I. If you find this connection you can measure 12V from pin 1 to pin 3. Knowing the passenger vanity light works says the 12V should be good because it bridges from the center dome light. I would start there.
Old 12-26-2014, 05:43 PM
One
One's Avatar
My 100 lets me close the sunroof with the key.
Old 12-26-2014, 08:31 PM
100A8's Avatar
My 92 100s has the same issues. Sunroof and power windows basically work when they want to. I replaced the relay for the power windows didn't help
Old 12-26-2014, 08:32 PM
100A8's Avatar
When u hold it in the lock position?
Old 02-19-2015, 02:02 PM
One
One's Avatar
exactly
Jay-S8
18
05-07-2021 12:50 PM
N'Syncro
33
02-16-2020 03:12 PM
CPLYONS
09-07-2015 07:19 PM
Budilica
New Member Welcome Area
09-04-2015 01:25 AM
zjw8407
09-02-2015 05:20 PM
Quick Reply: New owner of 100 CS questions (round 2)
