Rear Brake Rotor Removal
Hi
I am trying to install new brake rotors on the rear axel there is a Allenhead screw holding the caliper mount I cannot seem to find the correct size does anyone know what size this is or is it a special Audi screw
That screw is a standard metric socket head bolt. If your asking about the two bolts that secure the caliper bracket to the axle, it is a M10 x 50 mm long bolt, which has a 10 mm socket IIRC.
If anyone searches for this thread, you need an 8mm hex bit to remove the caliper bracket. I replaced the rear rotors and pads today on a 94 audi 100 S. Very stubborn rotor, PB blaster soaking for a few days and BFH did the trick.
mk4jetta
Audi Original "S" Cars
06-24-2010 06:07 PM
mrsteve
10-08-2003 01:50 PM
gerry14
06-29-2002 01:35 PM
