What is this?? 1992 audi 100 cs quattro
The line is part of the brake servo vacuum circuit. At least one section of it is made out of hard plastic, which I broke when I took off the intake manifold to replace the gaskets on the top end and the oil pressure valves. I had to patch it up, because you cannot find a replacement. In the next few weeks, I will replace the valve cover gaskets, and then I will do the experiment you did and see whether my '92 stalls as well.
The problem I'm having is the motor sounds starved at idle. Give it a little gas she sounds great but chugs and supters at idle. I was thinking the idle air, but if I unplug and start, the idle rises bit still chugging and returns when plugged in. If I unplug while running Nothing seems to happen.
Could be some adaptive memory in your ECU..you been running with an air leak.
Cap the leak. Disconnect the battery. Go have a beer. Reconnect the battery and reset you clock and radio.
Go drive the car for a while. See what happens.
sandorck
03-26-2017 10:45 AM
