1985 Audi Coupe GT Automatic cranks but will not start
Old 01-24-2015, 11:02 AM
audiwerld's Avatar
Default 1985 Audi Coupe GT Automatic cranks but will not start
Urgent help needed Audi GT Coupe 1985 Automatic 10 vave, 5 cylinder, lefthand drive,
I have issue with starting after having checked every component that might be reason to this fault...including timing, spark plugs injectors(CIS) oil and so forth but it cranks with no starting promise----help will be apreciated
Thanks in advance
Old 01-24-2015, 12:15 PM
Rogviler's Avatar
Well, it's either not sparking or something in the fuel system is faulty. Or both, such as the hall sensor in the distributor is bad, causing no spark AND not telling the fuel pump to turn on.
-Rog
Old 07-07-2015, 05:49 AM
5kcstq's Avatar
Did you check the fuse on the side of the fuse box that looks like it's a spare but isn't?
Old 01-28-2016, 09:47 AM
BDRMW's Avatar
What fuse is this? I am also getting crank but no start. I assume the fuel pump doesnt prime on this car, it only triggers when crank sensor sends a signal.
R83960
07-16-2018 01:51 PM
yawdi
11-25-2005 10:10 PM
CRLocky
11
09-17-2004 04:59 PM
SMOKEMAN
14
09-02-2003 01:38 PM
adelgreen
12-15-2001 04:51 PM
Quick Reply: 1985 Audi Coupe GT Automatic cranks but will not start
