Dreaded oil cooler "O" ring failure - AudiWorld Forums
Old 02-01-2004, 01:13 PM   #1
Default Dreaded oil cooler "O" ring failure
Got a call from my 18 year old son this morning, on his way to work the audi was making a "funny" noise so he stopped and checked the oil and it was down after only 15 miles!
I took a tow rope, the wife and a recovery vehicle and went to town. When I arrived the car was down 1/2 qt.(son had added about 2qt) and so I started it to see if I could hear anything out of the ordinary. Sounded ok so I let it run wondering where the oil had gone... then I saw oil pouring out from around the oil filter tho the filter was secure. Am I right in suspecting the oil cooler O ring? How long does it take to change? Any tips? Sure hope there wasn't any internal damage tho the buzzer never sounded! Looks like I'll be in the garage this week.
Packrat
PackRat is offline   Reply With Quote
Old 02-01-2004, 01:16 PM   #2
Default Re: Dreaded oil cooler "O" ring failure
BTW its a 4ks with 1.8l 4 cylinder!
Old 02-01-2004, 02:01 PM   #3
AudiWorld Uber User
Default It's pretty easy to do, just one bolt iirc.
You can use an oil filter gasket if you have one lying around and don't feel right paying $5 at the dealer for an o-ring.
Evilclown is offline   Reply With Quote
Old 02-01-2004, 02:57 PM   #4
Junior Member
Default I second that. It's easy to do.
Buy the o-ring, drain the oil, unscrew the filter and remove the big nut under the filter. The oil cooler should come off and you'll see the o-ring as clear as day. Just make sure you tighten the big nut all the way when reattaching the oil cooler. I had to use a set of tongue and groove pliers to get a good grip on that sucker.
See picture for a diagram of the seal you'll be replacing. Good luck.
JD
<img src="http://pictureposter.audiworld.com/11728/4cyl_oil_cooler.jpg">
Jeff Doble is offline   Reply With Quote
Old 02-01-2004, 04:24 PM   #5
Default Re: It's pretty easy to do, just one bolt iirc.
Well I took it off and the gasket was hard and compressed( and 16 yrs old) I had read that a filter gasket would do so I pulled one out and it seemed a slightly larger diameter so i'll wait till tomorrow and get the right one from the dealer (anyone know the part number?). The Bentley manual suggests that I coat the surface with AMV 188 100-02! Anyone know what that is? Would permatex do? Thanks for all the help!
Packrat
Old 02-01-2004, 06:26 PM   #6
Junior Member
Just put a thin coat of oil on it and it should be fine.
Old 02-02-2004, 07:15 AM   #7
dB
Default BTDT!
Mine broke too. Unfortunately, I needed a new engine. Shame on me. My dad changed the one in mom's car post haste after it happened to me. We aren't the only ones that should have this issue either. Just about any modern VW/Audi uses these coolers. I'm going to start changing mine every 100k miles to be safe.
dB is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
:: ECS Tuning :: NEW!! B8 A4 2.0T ECS Baffled Oil Catch Can ECS Tuning-Audi A4 (B8 Platform) Discussion 14 12-23-2016 04:46 AM
2017 S4 Spotted and it is... letS4nicate S4 (B8 Platform) Discussion 12 09-11-2015 08:46 AM
how much ATF fluid do I need? bilbo6209 A6 / S6 (C5 Platform) Discussion 14 09-04-2015 02:57 PM
:: ECS Tuning :: NEW!! B7 A4 2.0T ECS Baffled Oil Catch Can ECS Tuning-Audi A4 (B7 Platform) Discussion 0 09-01-2015 10:16 AM
:: ECS Tuning :: NEW!! B8 A5 2.0T ECS Baffled Oil Catch Can ECS Tuning-Audi Audi A5 / S5 / RS5 Coupe & Cabrio (B8) 0 09-01-2015 09:27 AM
Tags
18t, 2000, 27t, a4, amv18810002, audi, cooler, failure, filter, gasket, oil, oring, replacing, tt, vw
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
