need advice
#12
#13
I would just take the whole axle out. In fact, I'd just replace the whole axle instead of just doing the joint. It's not much more money, and it's way easier to do.
#14
It's a requirement in the Bentley manual to put a thin coat of red Loctite on the axle splines where it slides in to the hub. If someone interpreted "thin coat" as slather it on, then you may not get it out with a hammer. You may need to use a three jaw puller on the hub face to drive out the axle. You risk unseating the hub flange from the bearing, but it would get it out. The last thing would be to use a torch on the axle joint to burn out the Loctite. You will have to replace the bearing though because you will most likely cook the grease and seals in the bearing. Lots of options, but it depends on how deep you want to go with it.
#16
I guess I'm confused. Are you trying to separate the CV joint from the axle shaft or trying to remove the axle from the wheel hub? If you are trying to separate the CV joint from the axle, then I would agree with everyone that it's cheaper and far less stressful to replace the whole axle.
#17
davparf
Q5/SQ5 MKI (8R) Discussion
38
09-30-2020 05:01 PM
