need advice in regards to wheel changing
Old 09-21-2014, 07:54 AM
mar5den's Avatar
Default need advice in regards to wheel changing
hi again all im wanting to but the original alloys on my coupe gt for those who haven't read my previous posts i have 2 coupe gts one red and one blue the blue on is on the road and i wanted to switch the alloys over but the studs are different sizes the studs thats on my blue audi is larger and aftermaket i think they wont go threw the original alloys and the studs from my red audi are to small what do i do i want to switch them over but know what to do thanks in advance
Old 09-21-2014, 08:13 AM
Rogviler's Avatar
Are they studs or bolts? If they're studs, just remove them (usually a hex wrench) and hopefully whoever put them in used the correct size. I bought a 4000 where they used imperial threads in the metric holes, so I had to replace all the hubs. I'd use the original bolts myself, but if you want to stick with studs just swap them.
If they're bolts then that would be fishy if they're larger. I'd wonder what they did to the holes in the hub.
Also make sure you have the correct lug type. It should be ball seat for the original wheels. Aftermarket wheels are usually cone seat. Mix them up and the wheel can come off while you're driving...
-Rog
Old 09-21-2014, 08:36 AM
mar5den's Avatar
its a bolt and that whats i was thinking as the old bolt is smaller could they have threaded the hole bigger
Old 09-21-2014, 11:39 AM
Rogviler's Avatar
It's possible that they made the holes bigger. Are they both 4x108? Up to '84 the CGT was 4x100 and used the 12mm bolts versus the 14mm ones on all later B2s except the FWD 4000 (80 for you). That's the only difference I can think of that would be stock, at least based on my experience with US cars. Could easily be a different story with the ones that stayed in Europe. There are some pretty entertaining variations that Canada got, so it's totally possible.
Can you gets some pics of the bolts or measure them?
-Rog
Old 09-25-2014, 05:30 PM
Joeltron's Avatar
You're a good man, Rog.
Old 10-02-2014, 04:49 PM
jchrisyoungren's Avatar
Default Good Man
Plus one for "Good Man".
Old 10-02-2014, 06:07 PM
Rogviler's Avatar
Thanks guys!
-Rog
jjyerro
02-21-2018 12:25 PM
ttedeschi3
09-04-2015 06:48 PM
Budilica
New Member Welcome Area
09-04-2015 01:25 AM
Yoshimura
RS 7
09-01-2015 07:41 PM
Quick Reply: need advice in regards to wheel changing
