1989 Audi 200 Turbo Quattro Wont Start
So I recently got an 89 Audi 200 turbo quattro 10v. I cant get it to start. Bought the car thinking there was a bad wire with the CPS, but found corrosion in the ecu. Then I thought it was a bad ECU from the corrosion and a possible short, so i got a new ECU. Still nothing. It's not getting spark, and I cant tell if it gets fuel or not. I tested each wire in the CPS, and the CPS. Each wire tested out good, no voltage drop or anything. The CPS is brand new and tested good. What next? I dont quite know what to do next. I might potentially get a new bay harness and swap them.
Have you checked TDC with the flywheel mark?
Have you tested the engine speed and ignition timing sensors?
Misaligned distributor and poor/no signals from those two sensors will not let the engine control unit permit spark.
You should be able to put a fuse in the fuel pump relay to determine whether the fuel pump runs when the key is on.
So it did diagnostic and it gave me blink pause blink, blink, blink, blink. which is 2111 right? Anyway book says that is something with the engine speed sensor. It's a brand new sensor, and I checked the wires for continuity, and put voltage through them and there was no drop. Also have a new ECU which i still isnt starting. I'm clueless on what to do
Well I just got a new engine harness. Hopefully if I replace that I'll replace a broken wire somewhere in the process. Thanks I'll check grounds and use starting fluid tomorrow!
I'm getting spark sometimes. But not all the time. I was able to start it with starting fluid, reved it to 2k and then it died. I put a fuse in the fuel pump relay with the key on and it sounds like It's pumping fuel. What else should I check and what should I do?
Found that the cps fuse was a 5 amp instead of a 15. Swapped it and started getting spark. So it wants tone start, it fires a bunch but doesn't start. Getting codes 2112, 2113, and 2221. I'm thinking a missing vacuum line somewhere is the cause, as that's what 2221 is and I can't find any missing
