1991 200 Quattro Ignition switch replacement problem
Old 04-06-2015, 11:58 AM
Logos's Avatar
Default 1991 200 Quattro Ignition switch replacement problem
my ignition switch broke. And it burnt out the wire going to my starter.I replaced the starter and the switch
Import Direct Ignition - Ignition Switch Part # 18-0550
Once I plugged it in, I turned the ignition switch with a flathead screwdriver before inserting it into the back of the lock cylinder. The car started. But, no matter how many times I insert it into the locking cylinder, I cant get the key to turn on the car. I saw a mechanism in the back of the cylinder that obviously syncs up with the switch and locks into some grooves.However, no matter how many times I try and slide it in place, it never works.
Heres a few pics of the switch and the back of the locking cylinder. Its extremely hard to take pics of the locking cylinder, since its so deep in the dash.
https://drive.google.com/file/d/0B0b...ew?usp=sharing
Does anyone know how to install the switch properly, so I can turn my car on again?
Old 04-06-2015, 12:03 PM
Logos's Avatar
I attached the pics I linked to above.I couldnt find out how to edit my post
Old 04-08-2015, 10:31 AM
yodasfro's Avatar
Looks like the tang at the end of the lock cylinder is broken time for new a lock cylinder.
Old 04-10-2015, 09:34 AM
Logos's Avatar
@yodasfro
Yes youre right,I think the lock cylinder is broken.Do you know where I can find a guide to replace it?All the guides Ive found are years old and the picture links are dead.
Old 04-10-2015, 10:02 AM
yodasfro's Avatar
Easiest thing to do would be to replace the whole housing with a good used one.
It's held to the column with one anti-tamper torx bolt. If you need one I have a few good used ones.
Old 04-19-2015, 11:57 PM
Logos's Avatar
Default I appreciate the offer
Thanks but this is easier.
[V8] Ignition Lock Assy R&R?
Old 04-20-2015, 09:13 AM
yodasfro's Avatar
If by easier you mean the same exact thing then sure.
Old 04-20-2015, 11:36 AM
Logos's Avatar
Replacing the lock assembly tumbler is easier than replacing the lock housing.They are two different parts
handyr
A4 (B8 Platform) Discussion
07-14-2018 03:26 PM
Elkhart La6
Audi 100 / A6 (C4 Platform)
12-24-2010 04:37 AM
rickjl
03-21-2007 05:29 AM
boxster02
08-15-2006 11:15 AM
audinatic
11-23-2003 12:57 PM
Quick Reply: 1991 200 Quattro Ignition switch replacement problem
