Is the 1st fan speed and after-run pump work with the same relay?
Old 04-28-2015, 11:12 AM
OMP
OMP's Avatar
Default Is the 1st fan speed and after-run pump work with the same relay?
I know that 1st speed from fan will come on when:
- Climate Control is in any postion EXCEPT ECON
- After-run temp switch with ignition off is activated( In this case, the auxiliary water pump will also be activated)
But, do these 2 actions are done thru the same relay, or is there a separate one for each action?
Thanks
Old 05-01-2015, 11:15 AM
audi_marv's Avatar
On my 5kT, the 1st speed fan relay is in the fuse box under the hood....and the after run relay is located in the 2nd aux fuse panel directly below the steering wheel.
Actually...the after-run relay is not a relay at all, but a control unit enclosed in a 2-3 in. tall relay case. I think the original is brown, but the newer replacements are black. Can't quite remember....but either relay #324 or #271
OMP
04-28-2015 05:34 AM
auditech1218
10-15-2007 02:30 PM
chmnyboy
09-15-2006 05:01 PM
NSX JR
07-27-2004 03:22 AM
pedroskova
03-04-2003 01:33 PM
Quick Reply: Is the 1st fan speed and after-run pump work with the same relay?
