'91 200 20v turbo quattro owner new to forums
Just thought I'd make a little post since I'm new here. I drive a 1991 200 20v Turbo Quattro. Joined up on here to try to get a little more info on my car since there isn't much out there. Here's a little bit of spec info:
20v Turbocharged 2.2l inline 5 cylinder
5 speed manual
K24 turbo pushing 14 psi of boost on it now but I have a K26 I would like to swap
Bilstein Struts and H&R Sport Springs
258,000 plus miles on it and still running like a champ!
previous owner chipped it and estimated it's pushing about 305hp
At the beginning of the winter I spun out into a snow bank and tore the rear bumper off, which cracked and also flung back smashing out the driver's side tail light and trim. I had a friend fix the cracked bumper cover...he does body work for a living, so it turned out looking better than it did before the accident! I also found a new tail light housing which is on its way, but I'm having trouble finding the trim. Audi has it listed as "Filler". I need the center filler for sedan part#443807443E and the left filler for sedan part#443807459E. They are obsolete parts to get direct from Audi, so if anyone has those parts or knows where I can find them, please direct me to the source! I greatly appreciate it! Here's some pics I took today after a nice washing!
5 speed manual
Welcome to the Forum, search and ask and I'm sure you will get help and information. Where in the Midwest are you? Those wheels look great and the exterior color looks fantastic. You don't see to many in that burgandy. What color is the interior?
A local upull it yard may be your best bet for the mouldings. I think they are easily broken from minor impacts so they are hard to find.
Good Luck, Bob
Good Luck, Bob
Good Luck, Bob
Good Luck, Bob
I should have the trim pieces your are after, however I may not be able to get to all of them until spring(parts cars currently buried in snow). The center piece is common to 5000's 100 and 200's but the side pieces are 200 20v specific. You may want try and find the center piece locally. I think I have one of the side trims removed already need to check what side. PM me if interested.
Cyclamen pearl effect is the name of the paint color code is Z3T
Here's a picture of the damage from the snow bank. As you can see the bumper cover was fixed. The new tail light housing is on it's way. You can see the missing trim around the top of the bumper cover.
Audi Other 1991 Coupe Quattro
jbrentd
02-11-2014 01:36 PM
gutefahrt
02-04-2007 06:32 PM
boxerfan
02-01-2006 07:37 PM
20valvito
Quattro: Turbo / Ur / Sport
09-15-2002 06:21 AM
