audi 5000 turbo break light warning
I had all the lines and breaks replaced. the system is not low on fluid and it is not leaking. The break light warning comes on at about 10 seconds when the ok turns off. Would I have to replace the break accumulator?. The breaks are working fine and stop the car well on all circumstances...thx..Also thanks for helping me fine the a/c condenser, it turned out to be a brand new one still in the box from a after market company.
Brake light comes off sometimes
the power steering fluid is okay especially at 50 a bottle. Can there be air in the system from when I replaced the brakes and lines
Brake light
Pumping 20 times when the car is off seems a bit too much, on mine, after the 3rd pump there's not much left, pedal's hard as a brick. If you are not losing fluids, if the brakes are operating normally, I guess the system somehow doesn't recognize something. I do not know if there's an error code for this....
