audi 5000 turbo break light warning
#12
Pumping 20 times when the car is off seems a bit too much, on mine, after the 3rd pump there's not much left, pedal's hard as a brick. If you are not losing fluids, if the brakes are operating normally, I guess the system somehow doesn't recognize something. I do not know if there's an error code for this....
#14
Correct: Three pumps to a stiff pedal after shutting off the engine is indicative of a failing hydraulic pressure accumulator. A good "bomb" should give you at least 15 pumps. The idea is to maintain power braking capability in the case of engine failure at speed.
Boerge
02-07-2009 08:50 AM
Scott_Napier
Audi Original "S" Cars
10
10-08-2007 10:21 AM
Audis or VWs 4Life
10-13-2005 07:22 PM
