Help finding timing mark of flywheel
Old 05-02-2012, 04:56 AM
thorleyb's Avatar
Default Help finding timing mark of flywheel
Read all the articles on timing the 3b, disregarding the timing marks on the crank pulley. Bentley and both the (well documented) articles on TB r&r show a port in the bell housing through which the flywheel timing mark can be seen.... I've been at this all night and can't find that port.
Old 05-02-2012, 08:36 AM
Kneale Brownson's Avatar
I use a flashlight pointing through the mess of wires and hoses/tubes and can just barely locate that stupid window. I've done it dozens of times and it still takes me a while to get the light just right so that I can see the window. Then, finding the mark on the rusty flywheel is the next challenge. Once you find it, put some white or yellow paint on the mark. On my 200q20v sedan, I found it the first time with all the plumbing out of the way. I was redoing the hydraulic pump system and the crankcase ventilation hoses, so it was easier. On my avant, I painted the mark when I did the clutch.
Old 05-02-2012, 01:26 PM
thorleyb's Avatar
I just went at it again, I find 3 round ports on the driver's side of the transmission housing, of course since they are on the side of the housing I can't see to the bottom of the ports if they are in fact ports. The articles I've perused indicate top of the housing drivers side.
I'm looking at it with several lights but can't see anything that looks like the port shown in the articles and Bentley.
anyone have a hint? arrrgggh
Old 05-02-2012, 01:39 PM
yodasfro's Avatar
Kneale is right it's a bit of a PITA to see the window on a 20v.
http://www.sjmautotechnik.com/troubl...g/eng.html#tim
Old 05-02-2012, 01:43 PM
thorleyb's Avatar
so am I right, this is on the top of the housing? maybe a little to the driver's side?
thanks
Old 05-02-2012, 01:50 PM
yodasfro's Avatar
Here's a few pics I just took just for you.
Old 05-02-2012, 01:53 PM
thorleyb's Avatar
thanks man. You saved me from a messy suicide...
Old 05-02-2012, 04:07 PM
Wow, Yoda, I've never seen that window clearly enough to think of taking a pix. Great job!! Hope the OP realizes that it's down the side, not on top or bottom.
Old 05-02-2012, 05:03 PM
thorleyb's Avatar
yah, with those photos I went right to it. The images in the articles including the Bentley diagram had me looking for something much smaller..
thanks for the help
Jerry Tunin
09-12-2013 08:37 PM
pureroundcircle
02-21-2010 10:46 AM
Frankyle
Audi Original "S" Cars
07-21-2008 08:05 PM
tom050
05-03-2003 11:03 PM
audi8T
11-06-2002 09:30 AM
Quick Reply: Help finding timing mark of flywheel
