chipped 1988 5000CSQT fluctuating idle
Old 03-19-2016, 07:26 PM
DannyG123US's Avatar
Default chipped 1988 5000CSQT fluctuating idle
1988 5000 CSQT idle will fluctuate from 1500 rpm down to 400rpm when i come to a stoplight the check lights (battery, antilock,etc) car will flash one time it fully turned off and had to jump it any advice would be highly appreciated
Old 03-20-2016, 06:29 AM
richard-tx's Avatar
If you had to jump it to get it going, get a new battery or fix that issue first.
Old 03-26-2016, 10:12 PM
bradwilcox's Avatar
Is it because of the chip or is that just coincidental?
Bad alternator? Belts? Ground? ISV? Fuses missing or broken (check ALL).
Old 04-04-2016, 09:33 AM
GroupBquattro's Avatar
If you think it's the chip, do you have another ECU to replace ? Was it running all good before the chip ? The car should run fine even with the ISV disconnected, you can try that. The belts can be easily inspected, but usually they only make noise, or if they are loose, you can tell. Doubt it's the alternator.
AudiCoupeV6
1.8T Discussion
01-17-2008 10:19 AM
brianmski
12
01-06-2004 03:23 PM
KNaudiA4
12-06-2003 10:52 PM
Damisguy
10-21-2002 09:06 AM
steve
01-03-2000 08:40 PM
Quick Reply: chipped 1988 5000CSQT fluctuating idle
