Clutch Judder
Old 01-21-2015, 08:46 PM
Standard Issue's Avatar
Default Clutch Judder
Hello all I've another problem to try solve. I replaced the engine which had a new clutch plate, pressure plate and release bearing. I also had the flywheel skimmed but after putting it all back together a quick test shows there's very bad clutch judder. Clutch was fine before I removed it but I decided to change it for the long term..
Can anyone help with this clutch judder problem. It happens at pulling away speeds (forward or reverse) but is gone when the clutch is released fully.
Am I looking at removing the engine again? Could it be anything simple?
Old 01-22-2015, 08:10 AM
yodasfro's Avatar
Check the center support bearing on the propshaft and the u-joint too. Assuming the car is a quattro.
Old 01-22-2015, 11:33 AM
Yes the car is a quattro and I'll have a look at the prop and UJ. However the judder is quite noticeable as a definite vibration as you let the clutch out without the car moving hardly at all so I think it's related to the clutch components. I'm resigned at this point to taking the motor out again but not sure what I will be looking for that's causing the problem.
Old 03-05-2015, 01:05 AM
After another engine removal it turns out it was a faulty friction disc. New components solved the problem. The disc looked ok to the eye but there must have been a slight warp to it. Got engine removal down to 3 hours so that's good..
875ktq
10-06-2007 12:49 PM
Tanner
A4 (B7 Platform) Discussion
09-30-2005 01:31 PM
AndrewsQuattros
10-17-2003 05:07 AM
Lurk'n
09-18-2001 05:05 PM
Quick Reply: Clutch Judder
