Clutch Master Cylinder Replacement - AudiWorld Forums
Old 02-02-2009, 03:25 PM   #1
Member
Default Clutch Master Cylinder Replacement
I posted about a week and a half ago about leaking fluid coming from above the clutch pedal. Haven't been in the car for awhile, I've been busy with school and haven't been driving lately. Finally got to taking some pictures today and man am I glad I haven't been driving it around. Fluid is LOW and I think I found the problem, I'd like some help confirming.
You can see the drips coming off the hex nut and just above it. I think it's that gasket, I tried to get my fingers in above and around it and got no fluid on them, so I don't think it's coming from above.
<img src="http://pictureposter.audiworld.com/109747/0202091455.jpg">
Here's a photo of the reservoir, very low. Is it brake fluid or pentosin that should be used?
<img src="http://pictureposter.audiworld.com/109747/0202091453.jpg">
How much does replacing the clutch master cylinder suck? The part seemed pretty cheap... $60... but bleeding the entire system doesn't sound fun to me. Also, when I depress the clutch it is making a squeaking sound under the car when depressed that I have NEVER heard it make before, is that an effect of the low fluid?<ul><li><a href="http://forums.audiworld.com/v8/msgs/139539.phtml">Last Post</a></li></ul>
smcg3 is offline   Reply With Quote
Old 02-02-2009, 06:26 PM   #2
AudiWorld Uber User
Default the clutch master uses brake fluid. Check the hose that runs from the reservoir to the CM
for leaks. If the hose is solid then your CM is leaking. It's awkward to get at, but not too bad to do. Had to replace the one on my old 5K while it was parked in the street. Good times.
noriceforyou is offline   Reply With Quote
Old 02-02-2009, 07:48 PM   #3
Mister Bally's Avatar
Default Easy job
One of the simpler Audi repair jobs as it's all right there by the pedal.
Audi recommends pressure bleeding. I bought the "cheap" Snap-On pressure bleeder &amp; VW/Audi brake reservoir cap for about $250 back in 1994 or so.
Apply pressure &amp; fluid to the brake system and loosen the bleeder nut on the slave cylinder on top of the tranny. Let about a 1/2 cup come out and it's sure to be bled properly.
Mister Bally is offline   Reply With Quote
Old 02-03-2009, 01:01 AM   #4
Member
Default Yikes, $250 15 years ago?
I don't think I'll be using the bleeder for anything but this one job, so that might not make sense for me. I would do it in a heartbeat if it didn't require that tool . If it really requires shelling out that much for the bleeder valve and then the part on top of that, it might get passed on to the mechanic. Anyone in the PacNW with a bleeder tool willing to help out a poor college student?
Old 02-03-2009, 04:32 AM   #5
Default Or, you could make you own.....
But I had access to all these parts from work with a junkyard cap.
<img src="http://pictureposter.audiworld.com/51307/pc270001.jpg">
Avant Sport is offline   Reply With Quote
Old 02-03-2009, 06:12 AM   #6
5000CDQturbo's Avatar
Default mine isn't as fancy as yours but she does the job :-)
<center><img src="http://pictureposter.audiworld.com/62578/brakebleeder2.jpg"></center><p>
5000CDQturbo is offline   Reply With Quote
Old 02-03-2009, 01:53 PM   #7
yodasfro's Avatar
You can get a motive power bleeder for under $50.
yodasfro is offline   Reply With Quote
Old 02-03-2009, 09:32 PM   #8
I wasted more time than I thought would be required just starting the pipe couplings
RussB is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
Introduction and pics of my new love LaserSVT A6 / S6 (C5 Platform) Discussion 64 01-19-2016 05:26 PM
A/C Replacement advice 2002 A6 2.7t Mark VII A6 / S6 (C5 Platform) Discussion 9 09-28-2015 05:27 PM
Deciding between a Golf R or an S3- Need some opinions Captain Rossness Audi A3 / S3 /RS 3 MKII 26 09-24-2015 06:34 AM
Have misfire in cyl. 4 so i swapped icm's and now it won't start period. anticsAK A8 / S8 (D2 Platform) Discussion 0 09-06-2015 06:34 AM
95 Cabriolet Air Conditioning Clutch Removal. stormchaser1967 Audi A5 / S5 / RS5 Coupe & Cabrio (B8) 1 09-02-2015 01:47 PM
Tags
5000, a4, amb, audi, b5, b6, bleeder, clutch, cylinder, master, pressure, replace, replacement, reservoir, slave
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
