How long to replace front wheel bearing ? 1989 Tq - AudiWorld Forums
Old 11-12-2008, 07:13 PM   #1
Pushbutton_auto's Avatar
Default How long to replace front wheel bearing ? 1989 Tq
How long to replace a front wheel bearing on the 200 exclusive, turbo quattro, 1989.
And any extra tips.
Pushbutton_auto is offline   Reply With Quote
Old 11-12-2008, 08:17 PM   #2
Default Re: How long to replace front wheel bearing ? 1989 Tq
You'll need a press or a Hub Shark. Without those you'll be hard pressed to get it done period.
Good Luck
V8QinNJ is offline   Reply With Quote
Old 11-13-2008, 03:35 PM   #3
And with a Hub Shark, plan on a couple hours minimum.
You still have to pull the axle out of the bearing housing either by disconnecting the suspension or undoing the inner CV, do the pressing, which can be quite pressing in my experience with the Hub Shark, both out and back in, as well as remove the old bearing inner from from the hub.
Here's the Hub Shark puller working on the outer bearing on my 200q20va. This is the setup for pulling the hub. I didn't realize how much pressure was going onto the bar when pulling the bearing outer portion until I took the pix. Then I reversed the "feet" to put the support closer to the screw.
<img src="http://www.pbase.com/kneale_brownson/image/105198812.jpg">
Here's how the Hub Shark's little puller works on removing the bearing inner from the hub:
<img src="http://www.pbase.com/kneale_brownson/image/105198746.jpg">
Kneale Brownson is offline   Reply With Quote
Old 11-13-2008, 04:43 PM   #4
Default Re: Excellent, Kneale
thanks,
Thread Thread Starter Forum Replies Last Post
:: ECS Tuning :: B5 A4 1.8T Single Mass Flywheel Kit ECS Tuning-Audi A4 (B5 Platform) Discussion 0 08-31-2015 02:12 PM
Audi A4 FS Avant Garde M230 in mass piotrekmile Parts For Sale 0 08-31-2015 10:39 AM
Audi Other audi 100 control arm dorman aud100/520-717 rupenzelleo Parts For Sale 0 08-30-2015 03:21 AM
Gilfberg's A4 Build ign 5 A4 (B6 Platform) Discussion 2 08-29-2015 03:45 PM
Clicking when turning, but not the CV Jks2327 A4 (B6 Platform) Discussion 0 08-27-2015 03:43 PM
Tags
1986, 2000, a8, audi, bearing, bearings, change, front, hub, long, quattro, replace, tt, wheel, whenn
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
