How long to replace front wheel bearing ? 1989 Tq
Old 11-12-2008, 06:13 PM
Pushbutton_auto's Avatar
Default How long to replace front wheel bearing ? 1989 Tq
How long to replace a front wheel bearing on the 200 exclusive, turbo quattro, 1989.
And any extra tips.
Old 11-12-2008, 07:17 PM
V8QinNJ's Avatar
Default Re: How long to replace front wheel bearing ? 1989 Tq
You'll need a press or a Hub Shark. Without those you'll be hard pressed to get it done period.
Good Luck
Old 11-13-2008, 02:35 PM
Kneale Brownson's Avatar
And with a Hub Shark, plan on a couple hours minimum.
You still have to pull the axle out of the bearing housing either by disconnecting the suspension or undoing the inner CV, do the pressing, which can be quite pressing in my experience with the Hub Shark, both out and back in, as well as remove the old bearing inner from from the hub.
Here's the Hub Shark puller working on the outer bearing on my 200q20va. This is the setup for pulling the hub. I didn't realize how much pressure was going onto the bar when pulling the bearing outer portion until I took the pix. Then I reversed the "feet" to put the support closer to the screw.
<img src="http://www.pbase.com/kneale_brownson/image/105198812.jpg">
Here's how the Hub Shark's little puller works on removing the bearing inner from the hub:
<img src="http://www.pbase.com/kneale_brownson/image/105198746.jpg">
Old 11-13-2008, 03:43 PM
Default Re: Excellent, Kneale
thanks,
Airbag
21
12-08-2008 12:44 PM
rggpa2
11-21-2006 01:56 PM
hawist
10-26-2004 05:48 PM
FixedWing
17
10-01-2004 10:48 AM
odelay12v
03-10-2003 08:21 AM
Quick Reply: How long to replace front wheel bearing ? 1989 Tq
