Misfire! Please help! Wet distributor?
Old 04-19-2015, 02:58 PM
Commander Peppy's Avatar
Default Misfire! Please help! Wet distributor?
Hey guys. Drove my car through a little puddle and it's developed a misfire. What's the first thing to look for? First Audi I've owned so I'm not messing around.
Thanks,
Joel.
Old 04-20-2015, 09:14 AM
yodasfro's Avatar
What audi model is your car?
Old 04-20-2015, 09:30 AM
Sorry. I thought my signature posted with the thread. '91 Audi V8 Quattro.
Old 04-20-2015, 09:46 AM
tenspeed's Avatar
Back in the old days, I used a product call "Wire dry" or something like that. I would remove the distributor cap and plug wires, clean them good and apply a couple/three coats. Install the wires and give it another coat in place. The stuff was like a clear plastic that sealed the ignition system. Held up during water crossings with the Jeep and rally cars.
I did find these on Amazon and they seem to have similar properties.
Amazon.com: Gunk M1306 Wire Dryer - 6 oz.: Automotive Amazon.com: Gunk M1306 Wire Dryer - 6 oz.: Automotive
Amazon.com: CRC Wire Dryer, 6 Wt Oz: Automotive Amazon.com: CRC Wire Dryer, 6 Wt Oz: Automotive
Old 04-20-2015, 04:42 PM
V8BOB's Avatar
It's very possible that the water splashed up, hit the down pipe and the steam/vapor got into the cap and the wires. You have 2 distributors on this car so check the one and the wires on the side you hit the puddle. Be very careful if it's the right side distributor, that side has the "Hall Sender" on it and can easily be damaged if mis-handled. I would carefully pull the plug wires off one by one, inspect them for arcing or deterioration. Once again, be careful, a new set of wires will run you around $225.00. New caps and rotors are substantial too.
If you don't have a belly pan maybe stay clear of the big puddles, and be sure to report back here with the results.
Bob
Old 04-25-2015, 05:09 AM
Kneale Brownson's Avatar
When it's dark out, spritz the wiring with the engine running and see if there's indication of spark loss.
credlewi
05-07-2012 04:38 AM
schnitzelboy
11-12-2009 02:57 PM
grspider
A4 (B7 Platform) Discussion
08-04-2007 10:46 AM
punkbomb138
06-06-2006 03:19 AM
dewdman42
42
10-08-2001 08:39 PM
Quick Reply: Misfire! Please help! Wet distributor?
