My new find...91 20V avant...with questions
#11
Ok so a quick update.
I'm digging in to replace the thermostat, water pump, valve stem seals and other bits and bobs. I have a few questions.
1. Can you remove the thermostat without removing the radiator? It looks like it might be possible just a really tight squeeze.
#12
You can remove the thermostat without removing the radiator but removal of the p/s pump is necessary. Also removal of the intercooler. For a new thermostat you want the 87* C behr or wahler brand. Or from the dealer which is best but be aware you need to order the o-ring separately at the dealer, new bolts for the cover are good idea while you are at it. You can order dealer parts online from one of the any discount dealerships I use Carson at http://millburnaudiparts.com/ just create an account and e-mail him cheter@dchmillburnaudi.com to have him set your account up for a discount.
Are you replacing the timing belt and components along with the water pump?
#13
#15
Good news is that the thermostat is in just fine without any unnecessary removal of even the power steering pump and torqued to proper specs. And also the pulley and water pump are in. Now for the trickier parts....the crank seal, camshaft seal and all of the valve stem seals.
Any tips before I go into it?
#16
This shows whats involved changing the valve stem seals with the head on it's for a 10v but the same basic idea requires some special tools
??? ???????? ?????? ??? ? ????? ??????? ???????? ?? ????????? ???? 100 | ??????? ?????????????
#17
Update time. Seals are all replaced after having to locate a valve spring compressor that isn't the clamp type. I only have one final question for putting it all back together...when
I put in the valve lifters, do I need to make sure that the little hole on the side of the lifter is in line with the oil jet hole on the engine?
#19
Long term update. Car was finished on the 1st of this month and everything is going great. After a couple tricks with the valve cover gasket not wanting to seal and leaking, it's all going good. No leaks and no burning. Now it's time to work on everything else. Here's the list so far...
Bad wheel bearing on front drivers side. Have the parts just have to get someone with a bearing press to install them.
Dash still shorted out. Found a company who will rebuild it for $150 in Idaho. (recommended by Audi shop)
Air Intake Temperature sensor needs replacing.
Clutch has some weird play in it where it will take 2/3 of the pedal before I actually hit clutch. I looked at it and it seems to be the mount where the spring sits for the pedal. I don't believe it has to do with the slave cylinder just because of how it changes so much.
Still needs a radio (LOW on the list)
Need a differential and transmission fluid change.
Need to lube parking brake cable
Cruise control won't engage.
Rear D-pillar trim pieces need the cloth reglued.
Has trouble starting in the cold.
Needs new engine and transmission mounts.
That's all I can think of at the moment, but I know there are more. So time to go down the list!
#20
Another long term update....Sorry for the wait folks!
Been driving her for a month now on the new parts. She still has a leak out the front from the oil pump. It leaks decent but not enough to worry. Oil burning has all but ceased. I recently switched to full synthetic and funny enough, that helped it with a lot of its little issues.
Main things right now are air temp sensor which is throwing codes, wheel bearing, dash and new brake pads.
Oh and interesting news on the clutch. It started getting to the point where the clutch almost wasn't disengaging entirely, so I took it into the shop and they did a full flush of the brake and clutch system. Come to find out, the previous owner installed a new master cylinder, but never clipped the end off the nipple that feeds fluid to the clutch, so this car has been clutching without fluid for who knows how long. Feels great now!
Anyone know where I can get the air temperature sensor?
