PRND321 LIT
Old 11-02-2014, 05:42 PM
90jcv8's Avatar
Default PRND321 LIT
Transmission seems to shift all gears... But wont kick down. only in sport... But lacks power drained trans fluid put amount said online...still doing same. just prnd321.
Old 11-04-2014, 06:26 AM
toml99's Avatar
You can blink out the tranny fault codes unless you know someone at a german shop/dealer with the VAG 1551 tester....If you don't know how to blink codes go to SJM autotechnik's site. Good luck. I know the Multifunction Switch has been guilty before. Tom
Old 11-05-2014, 04:59 PM
90jcv8's Avatar
Would a led light with wires then the jumper work ? If put something together to blink out codes. Was trying to find one of those to buy. Haven't found a site yet
Old 11-06-2014, 06:09 AM
toml99's Avatar
Yes, $3 Radio Shack LED and a jumper wire. I crimp mini male blades to the ends so they fit nicely into slots. I've had 2 parts cars that had messed up slots from someone using something larger....Good luck, Tom
Old 11-06-2014, 06:18 AM
toml99's Avatar
Also, pretty sure kickdown switch is part of throttle cable right at firewall where the cable housing commonly breaks.
Old 11-08-2014, 01:04 PM
90jcv8's Avatar
I got a 1111 code and another for idle speed valve.. Was only codes that kept flashing over and over on led light while running
Old 11-08-2014, 01:06 PM
90jcv8's Avatar
I found multifunction switch on trans with plug in was greasy around it but inside wasn't to bad.. I'm spray that off all under there clean up see what happens then the control unit defective think what code stood for
c4S6
Audi Original "S" Cars
05-13-2007 04:49 PM
smoothcruiser
04-17-2004 05:37 AM
Speedwagon1.8T
10-15-2003 11:06 AM
Imola Ghost
12-08-2002 09:00 PM
NCFioren
01-08-2002 08:42 AM
Quick Reply: PRND321 LIT
