Replacing Starter 1990 Audi V8 Quattro 3.6
How difficult is this job of replacing the starter in a 1990 V8 Quattro (3.6)?
I have a remanufactured Bosch Replacement #SR410X
Thank you!
Rein
Thank you!
Rein
I did not find a detailed step by step procedure but here are some links to some anecdotal prcedures...........
Sounds like the bolt that goes into the starter from behind is going to be the one that will test you.
http://www.audiv8.com/forum/files/29...87_starter.JPG
Starter motor removal - www.AudiV8.com - Audi V8 Forum / Audi A8 Forum
http://www.justanswer.com/audi/6es1k...d-starter.html
Starter removal 1990 audi quattro v8 - Fixya
Good luck with that. I'm sure there are others that will chime in with some good advice for you.
Bob
Bob
The 10mm Bolt in Question...
Is the 10mm bolt in question visible through the right fender-well opening on the backside of the bell housing, just above the hole in the bell housing?
I have looked and looked, and that appears to be the one.
I have to change the right front CV half shaft and both lower control arms, so I think its best to get to that bolt and do the starter after I get the front suspension out of the way.
Rein
Rein
Not at my computer, but found an old link.....Cut a 10mm allen to about 1-1/4"....With passenger distributor out you can look down and see bolt...get allen on as deep as possible as that bolt won't want to come out and you certainly don't want to strip it. 10mm box end and short piece of pipe should break it loose....then if you want, ratcheting box end makes it a bit easier....Don't use ratcheting box end to break bolt loose, or you'll break it like I did. Don't remove bolt all the way, just slide it back. Verify switch wire isn't all baked like most of them....Good luck, Tom
http://tinyurl.com/bulho8e
One trick I've found on the control arms is to wrap a ratchet strap around swaybar and compress it inward so when you get the nuts off the ends, it slides right out/back in. Tom
treehunter
05-04-2007 05:22 AM
98a6quattro
12-28-2001 08:10 PM
dickball
12-26-2001 03:11 PM
