Starting issues--Audi 5000 Turbo
my 1986 Audi still occasionally won't start when warm. The mechanics cannot figure it out, it takes five min to start and it seems to be rough for a second. Otherwise it runs perfectly, it is not the injectors. Either it is not getting gas or air or it is flooding but I have a clean exhaust. out of 3 mechanics no one can figure out the problem, there are no error codes. The computer says ok. I am using 91 octane fuel, new filter, all wires, cap, distributor and plugs have been replaced. Injectors are working fine, engine never stalls. 90 percent of the time it starts on the first turnover, even when it is hot. The cooling system and high power fans are working perfectly, the a/c works, the cooling fan comes on after the engine is shut down when needed. All the systems seem to be working properly....PLEASE HELP
Three things required to start & run. Compression, which we know you have since the car runs fine most of the time. Fuel and Spark. When she won't start, determine if you still have spark by removing a plug wire and insert a small screwdriver and place it close to a ground point. Crank engine and look for spark. Or, insert another spark plug in the removed plug wire and place on a ground point and look for spark when cranking. No spark; fix ignition problem. Probably either a bad coil or Hall-Effect sensor. If you have spark, fix the fuel problem. Probably a bad fuel pump relay (they do go bad and behave intermittently before failing 100%. They are easily bypassed temporarily to limp you home with a jumper wire with two male blade terminals. Or a bad fuel pump or wiring between any of these points.
I have had the ground terminal on the top of the engine corrode at the crimp on the ring terminal causing a no-run, no-start condition as well. This causes a "no spark" condition too as I believe it affects the coil from firing.
You have a fuel pump in the fuel tank.
Is your car a turbo model?
Warm no start can be due to weak signal from the igtnition timing sensor. You need a good signal from that and the engine speed sensor to get spark.
Leaking spark plug wiring can also cause start difficulty on warm/moist days. Try spritzing the spark plug wires with water in the dark and see if there's a light show.
Again, warm start issues can be the ignition timing sensor. It's an easy test described in the Bentley manual.
As mister bally notes, there also can be issues with the engine ground wires corroding.
No start when hot?
"Classic" fuel pressure not holding up when hot (and motor shut down), so you kind of get a form of 'vapor lock' that lots of cranking gets you around (eventually!)
Typically due to:
Leaking injectors, bad check valve in fuel pump, or accumulator not holding pressure..
Typically due to:
starting problem solved in Audi 5000cd Turbo
The car has started well for two weeks even though I am scared to try every time I get in the car. I read the owners manual and of course you need to use only 91 octane, but they do not recommend ethanol blended fuels which may result in a vapor lock in warm to hot conditions or high altitude. You could also cause engine damage using less then 91 Octane or more then 10 percent ethanol. I believe, any ethanol is garbage in these 5 cylinder engines especially the turbo charged engines. Thx for the help too
1986 Audi 5000cs--starting problems solved
Don't use ethanol blended fuels, it results in a vapor lock at warm to hot temperatures and high altitudes, found this in the owners manual. Just have to figure out why my break light warning still goes off, and then clears after some highway driving, all levels and pressure check out....
forcefedfreak
10-03-2007 11:48 AM
