What does a bad wheel bearing do?? Is it dangerous to drive with a bad bearing? - AudiWorld Forums
Old 04-29-2002, 08:04 PM   #1
Senna4Life is offline   Reply With Quote
Old 04-29-2002, 08:32 PM   #2
cuatrokoop's Avatar
Default Re: What does a bad wheel bearing do?? Is it dangerous to drive with a bad bearing?
makes noise (some at first, then more, and more, and more, until you cook the bearing enough that it locks the wheel in question up). how much noise is it making?
cuatrokoop is offline   Reply With Quote
Old 04-30-2002, 12:59 AM   #3
Junior Member
If you are getting any squealing or grinding noise from the wheel in question, then park it until you know what it is for sure. Rock caught in the brakes? A wheel bearing going out only gets worse until it locks the wheel and gets very expensive. Put it on blocks and check it good.
crotext is offline   Reply With Quote
Old 04-30-2002, 01:34 AM   #4
Default Keep driving with a bad...
wheel bearing and soon you will wreck the hub. Then you will not only have to pay for a wheel bearing kit, but you will also have to buy a new/used hub...
Steve
Michigan
SteveAngry is offline   Reply With Quote
Old 04-30-2002, 07:46 AM   #5
Default RE: how much noise is it making?
Well...when driving straight it moans, (you can hear it, my friends tell me it sounds like an airplane) but if I turn the wheel a little to the left while still driving a little straight the noise goes away. If I let the wheel be straight again it comes back...
Thanks
Old 04-30-2002, 10:12 AM   #6
Junior Member
You're fortunate you can get your sound to go away. Mine thumps whenever the car is moving now, it got progressively worse in the past week. I'm going to check it for sure today to make sure it's the wheel bearing before I shell out money I don't have for a new one.
the red pill is offline   Reply With Quote
Old 04-30-2002, 02:02 PM   #7
Are you sure it's a bearing and not a CV joint? Bearings usually howl at all times, whereas the noise from a worn CV is sometimes steering-input dependent.
Audi200tq is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
Audi A4 FS: AWE Drive Train Stabilizer (B5 S4) d0nut s4 Parts For Sale 7 02-11-2016 05:48 AM
Adjust passanger seat from driver side fkaufman A7 4 09-07-2015 08:59 PM
Cabriolet steering wheel question mrprism133 Audi 90 / 80 / Coupe quattro / Cabriolet 7 09-07-2015 08:22 PM
08-09 4.2 TDI jigaro A8 / S8 (D3 Platform) Discussion 10 09-02-2015 06:42 AM
Got an A7, wanna ask some questions :) zhaoweitian A7 2 09-01-2015 04:15 PM
Tags
2001, a4, a6, a8, audi, bad, bearing, bearings, dangerous, defective, drive, driving, quattro, tt, wheel
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
