1988 audi 90 2.3 crank seal
Old 08-29-2015, 11:50 AM
Luke McNeley's Avatar
Default 1988 audi 90 2.3 crank seal
So same audi with the thermostat issue, the kid I bought it from said he had replaced the valve cover gasket so he said he had the oil leak fixed but I've been driving it and it can't hold oil to save it's life. I Just had a good mechanic look at it and he said it's probably the crank seal, if anyone here has replaced one before what should i look for and how hard could it be. Thank you
Old 08-29-2015, 09:24 PM
CRAZY_RUSSIAN's Avatar
front or rear? as the front your have to pop off the t-belt. rear is a nightmare and you have to either remove the trans or the engine.
find out for certain where its coming from, wash the engine, then go from there.
Old 08-31-2015, 01:46 PM
Default Front
It's the front for sure, I took it apart a little and found missing/broken bolts from the block. I don't know if this would cause the oil leak or if it's still the crank seal. Any advice would be helpful thank you.
Teo of em in between the belts<br/>
Old 08-31-2015, 04:50 PM
broken bolts can cause leaks, but again, wash your engine and then take a look where the leak is coming from
Old 09-04-2015, 02:12 PM
Lago Blue's Avatar
Default Where to start with your work plan research...
Hi Luke,
Here are some ideas you might use to begin to develop a repair plan. Whether you are doing this yourself or with help, the repair will require the application of this info. For brevity's sake, I will simply list where you should look and why:
a,) Bentley Publishers (official factory repair manual);
b.) Blaufergnugen Manitowic, WI (complete timing-belt, water-pump & crank-seal repair kit (not saying that is your issue BTW, but currently on sale?) and special tool rental ;
c.) Huw's (human speakers) audi site write-up on the above 3 related tasks (with photos) that, as you may already realize, should be done together if there is any doubt as to the age of these components and or to make best use of an intrusive procedure.
Also slightly related WRT oil leak finding technique, look for "austinado16" 's thread on the old A6 forum here re his repair of an oil-pump leak.
Hope this helps.
ECS Tuning-Audi
A4 (B8 Platform) Discussion
21
09-11-2021 04:04 PM
mrprism133
09-07-2015 07:22 PM
David Varela
08-30-2015 11:42 AM
Jiggie
08-30-2015 06:37 AM
Janryk
08-30-2015 02:12 AM
Quick Reply: 1988 audi 90 2.3 crank seal
