1994 Cabriolet Window and Radio Issues
I was just gifted by a family member a 1994 Audi Cabriolet. Runs great and in nice shape but a couple of things aren't working.
1. The radio, is the Gamma version and will not even turn on. The antenna is also not working and stuck in the 1/2 up position
2. The 4 power window switches on the driver door. The "all window" switch on center console works all the windows, and the passenger switch works it's window but the 4 on the drivers side don't do anything.
Any ideas or tips on things to check ( fuses, relay, etc) or parts that may need to be replaced would be great.
Thanks
Thanks
Check your fuse box for a fuse map.
The window switches are pretty easy to replace. You may have bad ones on the driver side. You can get radios and switches from junkyards. All Audis 1988-1995ish should have your switches. Check row52 dot com.
brad
Thanks for the info. Today took apart the door handle, cleaned the switches and presto window switches worked. I also got the HU unit out and replaced the blown fuse in the back of the HU and I am now cruz'in with tunes!
rkarsk
TT (Mk2) Discussion
01-22-2021 02:57 AM
pete1033
Audi 100 / A6 (C4 Platform)
06-15-2005 11:19 AM
