1995 90 wont pass emissions
Old 04-26-2016, 05:58 PM
ericmu17's Avatar
Default 1995 90 wont pass emissions
Hey all as you see in the desc. my 90 wont pass emissions (2.8 v6). It doesnt seem to have an exhaust leak but it does smell, almost like its carburated. strong exhaust smell. Any clue on points to start looking at.
Old 04-26-2016, 06:17 PM
abjb's Avatar
OBDII codes, auto supply will read them for you if you don't have a code reader.
O2 sensor
bad injector
Lots of other fuel related parts, how does it run, gas millage suddenly gone down?
A wise man at my local inspection station whispered in my ear that I should drive our 90's BMW on the freeway in a lower gear (get it nice and toasty) then come straight to see him, PASSED on the first try and the next 2 years.
Old 04-26-2016, 06:57 PM
ericmu17's Avatar
VAG sensor is on its way. Thank you.
Old 04-26-2016, 06:59 PM
ericmu17's Avatar
Dunno its new to me (92,245 miles). Great power, mileage seems good. Just stinks and wont pass emissions. Exhaust looks shiny and uncorroded all through out.
Old 04-26-2016, 07:36 PM
CRAZY_RUSSIAN's Avatar
VAG sensor? LOL
It's OBD-I, first of all. You call pull your codes 12v Pages - Maintenance after you do that, post them here
also post your results of emissions scan.
Old 04-28-2016, 06:01 PM
bradwilcox's Avatar
That "guaranteed to pass" additive might put you over the top (follow the directions carefully) but be sure to address the real issues.
We really need to know what the smog check station found, is the problem HC or what?
O2 sensor if it's old.
Old 04-29-2016, 04:34 PM
ericmu17's Avatar
Alright so do I need an obd1 or and obd2 scanner?
its a 1995 Audi 90 C with a 2.8l V6 30v, front wheel drive, Automatic Transmission
Old 04-30-2016, 04:39 AM
sanchius's Avatar
On my manual converted cab, I tracked down all the vacuum leaks & fixed the common plugged EGR system, and still didn't pass.
I then ordered a new set of catalytic converters from ebay for ~$110 each and passed with flying colors.
It turns out one of the original cats had been hit on something and lost its internal matrix.
<img src="https://c2.staticflickr.com/4/3879/14294229428_e8c6b100a4_b_d.jpg">
Old 04-30-2016, 09:17 AM
if you would of read my prior post, I'm telling you that it's an obd-1 car and i'm giving you instructions on how to pull the codes without a scanner 12v Pages - Maintenance
so lets try this again, do the scan, and report back with the codes, also post what areas of emissions you failed
Old 05-05-2016, 04:09 PM
visatrade's Avatar
I took my car to Interstate Batteries and the guy said it was OBD-II. I still dread needing to buy a OBD-I Scanner. Maybe he was mistaken? I know this car uses coil packs and not a distributer so timing isn't an issue. I am trying to pass California Emissions as well but my problem is blue smoke. I am going to use some "Restore Engine Restorer" in case it is the piston walls/rings and 20w-50 high mileage oil (even though it only has 165,000). If it is the valve seals I think I will try Marvels Mystery Oil. I only need to pass to transfer the title to my name. After that I will register it to a county that doesn't need to pass smog every 2 years.
Quick Reply: 1995 90 wont pass emissions
