KEY STUCK IN IGNITION
Old 05-18-2009, 06:52 PM
prijedor's Avatar
Default KEY STUCK IN IGNITION
I am guessing that is caused by bad ignition switch.My mechanic had switch replaced twice back in 2004 along with lock cylinder.After few months key would have to be pushed back after starting so i just gave up on replacing this.Now key is getting stuck in ignition so i would have to start the car again and then i can pull it out.
I have replaced this switch in 2006 on my 200q and never had any problems since.Is there a difference between dealer switch and Meyle switch from Blauparts or Autohausaz ?I don't mind paying extra for dealer part if that would solve this problem.
Old 05-19-2009, 08:12 AM
cabrioletturbo's Avatar
assuming it was installed properly and that your car is automatic, you should check position on the cable in the back of the lock and the release on the auto shifter.
otherwise, I have a lock and brand new ignition switch to go with, that worked and will work for you. $120 USD shipped.
Igor
cell 416-834-1049
93_Audi_90CS
04-07-2010 10:46 AM
El Desamparado
Audi Original "S" Cars
10-12-2006 06:14 PM
washparkS4
05-25-2006 08:50 AM
CalG
Audi 100 / A6 (C4 Platform)
05-10-2004 08:47 AM
audijim113
11-05-2002 04:13 PM
Quick Reply: KEY STUCK IN IGNITION
