'95 Cab CFS transmission leak.
As get get closer to the end of the most needed repairs on the Cabriolet repairs, one is still beating me.
I replaced the leaking oil cooler, the brake pressure control valve is on it's way, and proceeded to fix the leaking transmission by changing the tranny filter and gasket. But guess what, the gasket wasn't the culprit. It still leaks just as much now as it had before. I went back and did some more research, and found that the electronic connector right above the pan gasket at the back of the transmission has an O-ring. I would like to replace it. I don't know what else would be causing a leak in that location.
Does Rusty or someone else know if this o ring mounts on the inside or outside of the tranny case? Will I need to drop the pan again?
Thanks,
Shawn
Thanks,
Shawn
Sorry to say..looks like that "O" ring is on the plug connector on the inside. Pan must come back off to get to that "O" ring. If it is the harness connector
The "O" ring is part number 095325381A and about $2 or $3 from Audi/VW.
Be sure the connector itself is not cracked in there..look carefully. If it is cracked you need part number 097927365D and some time to replace it. About $90 online or about $220 from Audi/VW.
If it is the multi-function switch body with an "O" ring (I think that is back there behind the transmission too) that can be removed without dropping the pan..
OK, thanks. I hope to get the pan off in the next couple of days. Then I can see for sure.
The part listed shows it is for a 097/01N. Is the CFS just a version of that transmission?
I just need a day to get it on the hoist and take care of it. Also at the same time, I have to replace an axle seal. Along with the tranny fluid, there's plenty of gear oil splashed about on the underside of the motor.
UrSoccer_mobileĀ®
06-30-2008 12:13 PM
DeutschDriver
12-15-2004 12:52 PM
