Any idea why my fuel gauge needle goes up and down? mostly down of course
Old 09-29-2004, 06:36 PM
New Member
volk90s's Avatar
Default Any idea why my fuel gauge needle goes up and down? mostly down of course
it failed long time ago and I never had a chance to fix it. Usually when I put full tank of fuel it goes up and stays there for some time and then goes down and then sometimes up again. It is very intermittent. What is it? What are the costs involved to fix?
Old 09-29-2004, 06:45 PM
egp320i's Avatar
Default fuel level sensor it sounds like
its probably shorting out or just crapping out.
depending on car its going to be of course attached to the fuel pump which might have to be pulled to be replaced.
Old 09-29-2004, 07:26 PM
CvTech's Avatar
Default I just recently replaced parts of my cluster for this.
My new, actually used, cluster seemed to fix the problem. I think, for me at least, there was some short in the panel or even the gauge itself that this would happen to me.
My fuel gauge, when full, would go all the way to F. Then sometimes it would drop almost to E, then go back up like to 1/4 tank. Very intermittent readings.
I suggest finding a cluster, pluging it in and diagnosing it that way. If the new/used cluster gives solid reading...then you knwo its not the fuel tank sensor, to which I think is kinda hard and difficult to repair or replace.
Old 09-29-2004, 08:38 PM
SCarGo02's Avatar
Default The sender is quite easy, comes out before you do a fuel pump on a B4.
If you have factory tools for doing the fuel pump, it'll help speed up the process, but not necessary IIRC.
vin_akleh
01-15-2018 03:44 AM
A4_Maverick
08-16-2005 11:58 AM
Whitjr
01-26-2005 05:42 PM
FinnTT
06-09-2003 08:25 AM
Pancho225
23
07-25-2001 12:03 PM
Quick Reply: Any idea why my fuel gauge needle goes up and down? mostly down of course
