audi 90 Quattro Hesitation
So hello all, I just bought a 91 90 quattro and for whatever reason the check engine light will come on when accelerating in 3rd/4th/5th. Rarely will it ever be in 1st or 2nd. Even if I go wot. When I go wot in 3rd, it will usually send the check engine light on and retard the timing. When I shift however, It goes off until I accelerate past a varying rpm.
My guess is a knock sensor. I am running 91 octane in california. (****ty gas I know)
Just seafoamed the car and changed spark plugs.
I'll go ahead and mix 50/50 101 octane and 91 and see if that makes a difference, but I just want to see if anyone has an idea as to what it might be.
I searched all over and only found slightly similar problems but not exactly the same.
91 90 quattro is most likely a 7A 5 cylinder engine while the 95 Quattro is a v6, totally different animal
you should pull the codes. most likely knock sensors. easy to upgrade to the newer(donuts) style, and the proper torquing is very important.
Henry Toot Burney
Q7 MK 1 Discussion
15
11-11-2019 06:29 PM
