cambelt change
What engine do you have in the car? 1986 is too far for my memory. I think you have a 4 cylinder..1.8 ..yes? The pulleys will need to come off. The crank pulley (as I recall) is held on with four 6mm allen bolts. You should not need to remove the big crank nut. Should not be that difficult. There should be metal timing belt cover at the top ..held on with an allen inside a rubber sleeve..hard to see.
Hello mar5den,
If you still need the procedure, I used to have the same car '85 edition. Have some old pages I can email you on the procedure if you like.
All Z Time
08-25-2006 05:13 AM
parkpy
Audi Original "S" Cars
06-06-2005 04:32 PM
TonyDetroit
08-15-2004 11:01 AM
