code 00532 all I can do is guess atm
#11
Since my error code has gone with the speedo still not working I am still investigating.
I remembered today that the main 60 Amp fuse under the steering wheel has two red and a red black going to another set of fuses in which the other day I reconnected as one had popped out. As pictured:
Could this be the intermittant B+ to ecu as the fuse was half to three quarters out. One of that is.
I have replaced the fuse in under the hood as the instrument and various sensors 15 Amp number 12 I think it was.
#12
http://12v.org/urs/1996_Audi_Cabriol...g_Diagrams.pdf
On page three of the wiring diagram it shows a fuse #4 powers 12v to a red/blue wire to the transmission ECU..on pin 45 (not on pin 19, what the books says..but the Bentley has been wrong in the past)
Your ground wire from ECU pin 1 goes to the intake manifold..that cluster of grounds you usually can see on the RH side under the plastic engine cover..maybe they are loose or dirty?
The grounds for the instrument cluster look like they are on the left side , under the front of the car (G202). Power 12v is direct from the ignition switch (be sure your switch is good..a problem part in the past) and fuse 4 and 12. Those fuses may not be under the hood of the car but behind the footwell.
#13
PCB of the Cluster
Hi again , the second time I disassembled the instrument cluster I stumbled upon a crack at the corner of the fuel gauge, in the PCB board.
Trying to repair the board along these lines should have been simple and quick although my poor equipment made sure it took several hours since the soldering iron only gets hot on one part of the point up from the tip..
After soldering and de-soldering I tested continuity with a multi-meter and it should work fingers crossed for tomorrow am.
Its not a VDO board so from what I have read it may be a hitachi but with little labeling apart from the Audi rings I don't know but it is different from the guide for a VDO cluster to disassemble.
#14
Sorted
After getting new bulbs on the instrument cluster installed and tested on the bench as working I reinstalled and still no speedo.
Looked at the dam VSS plug to get it out ( the VSS ) and looked like a jacking job. So I took a short cut by just removing the plug which was corroded by winter water as were the pins on the VSS sprayed with CRC type fluid and good as new, the speedometer works fine..
So the old corroded pins on a connector joby, fixed now.
Teknic
11
10-07-2005 09:27 AM
marked001
05-27-2005 05:30 AM
m4rcus?
Performance and Tuning
09-16-2002 10:45 PM
mfjp
06-15-2001 06:45 AM
