Distributor issues 90 quattro 20V
I went to replace my rotor but had difficulty removing it. Turns out it was glued on. So i have to use vice grips to crush it and remove. I put the new rotor on put the cap back on and went to start it. Ram for all of 10 secconds then nothing. After messing around for a few hours of no starting my rotor will not spin. What is the issue? Ive heard the gear at the end of the distibutor could be broken or my cam could be broken. I am going to take it out tomorrow and see if the inside gear is broken or not
That is very strange..I've seen the rotors very hard to remove..glue would be unusual.
My guess would be the cam belt is broken..if the distributor is not spinning when the engine is cranked. The drive gear is very robust.
Could be the issue is the plastic gear..034 has a brass gear..if that is the problem.https://store.034motorsport.com/dist...di-i5-20v.html
Distro gears were originally plastic on MANY 7A engines. Also, all the rotors are originally glued on to the shaft. Most people don't glue replacements on.
Good luck with a whole new distributor. Just replace the gear. The distributor is likely NLA, like most parts for this generation of Audis.
quattrokyle
01-25-2008 08:18 AM
SLAB
17
04-21-2004 02:34 PM
