headlight loom wiring mod from b3 to b4 headlight conversion
#11
This is much simpler than u making it. As I said earlier Your only concern is 3 out of the 4 wires. driver side Hi beam +ve (W/B), Low beam -ve (Y/B), ground is brown. Pass side HiBeam (Yellow), Low beam(White). even with the S2 light, i believe the same rule apples. it should have 1 connector on it. or the the light come with the harnes. But if all else fails u can wire it however u choose with a lil electrical know how. Power on the light switch, with a test light probe the wire end to see which wire has power on low beam, then do the same for hi beam. then splice it in to the light harnes accordingly. Brown is always ground. then grab a beer
