How to remove ignition key cylinder?
Old 08-02-2007, 10:40 PM
DDMan's Avatar
Default How to remove ignition key cylinder?
So, since my ignition key cylinder broke, I have been trying to figure out how in the world I am to remove the ignition cylinder from the dashboard! If anyone can tell me how I would greatly appreciate it. I purchased a new cylinder, and keyset, and now I just have to put it in so I can get my radio back and dont have to start my car with a screwdriver.
Can anyone point me in the right direction? I searched, but all I can find is replacing the electrical part of the ignition switch, and not the key/tumblers/cylinder
Old 08-03-2007, 03:30 AM
New Member
v6nside's Avatar
Default Re: How to remove ignition key cylinder?
I just did this last weekend, really easy.
Remove the lower dash piece under the steering column. Remove the cover around the steering column (2 screws), you will see 2 screws holding the instrument cluster in place, remove and pull out cluster, disconnect wiring. You will now be able to see the top of the cylinder.
On the left and right you should see red paint covering 2 flat head type screws holding the cylinder in place, use a small screw driver to loosen the screw and the cylinder will slide out. Disconnect, replace, reverse the process. 10 mins max.
Old 08-03-2007, 04:00 AM
Tech Guru
4Driver4's Avatar
That's for the electronic portion only.
Old 08-03-2007, 04:03 AM
Tech Guru
4Driver4's Avatar
Default Look at the new cylinder.
Does it have a little spring tab on the side to lock it in? (I have no idea what year and model you have). If it has the tab, you'll need to locate the spot on the aluminum housing in the car where that tab should be on the old switch. Drill a 1/8 hole in the aluminum and use a small screw driver to depress the tab. Pop the cylinder out.
Old 08-03-2007, 04:47 AM
awdaudi's Avatar
Default installed.
<center><img src="http://www.ncaudi.org/gallery/albums/theringmeister/Aut_0611.jpg"></center><p>
Old 08-03-2007, 04:48 AM
awdaudi's Avatar
Default ....for about $9...here's how
<center><img src="http://www.ncaudi.org/gallery/albums/theringmeister/wiring.jpg"></center><p>
Old 08-03-2007, 05:41 AM
Tech Guru
4Driver4's Avatar
Default Um yeah. I really don't like those setups.
What does this have to do with the lock cylinder?
Old 08-03-2007, 06:57 AM
chefbob's Avatar
Tom is teh oem king
Old 08-03-2007, 07:12 AM
Tech Guru
4Driver4's Avatar
Default An ignition switch is $30 and can be replaced several times in the time it...
...takes for that mod.
Old 08-03-2007, 07:44 AM
chefbob's Avatar
meh! to you and your old fashioned way of thinking
Quick Reply: How to remove ignition key cylinder?
