Suspension? (80)
Suspension? (80)
Just got the world's best deal on a running, driving, stopping (after brake pads) 1988 Audi 80. This means I'm allowed to spend more on it (invest...) and feel okay about it.
I would like to enhance the suspension, right now the car just flops around corners. I had a 1985 Jetta with Bilsteins on it and that alone made corners a blast, no idea how old the parts were but not a current model. The only coil springs I'm finding for the Audi 80 are the Vogtland drop coils. Only 1.57 each, doesn't seem absurd and I could pair them with the 'sport' version of the HD Bilsteins.
Anyone ever use these coils, and what's the thoughts on this suspension choice?
Prior to making a shock absorber selection..check your shock mounts and "A" arm bushings..almost certainly those are all in need of replacement.
Front shock mounts:
And those often worn out "A" arm bushings on the left with a new lower ball joint:
034 has some high density/track/street shock mounts. I use them and if you lube up the bearings in the 034 shock mounts..they seem to work well.
I used a Sach Advantage shocks and new dust/bumpers covers.
Try and find Lemforder control arm bushings..there is some junk parts our there. Follow the book on pre-loading the front suspension prior to tightening the "A" arm bolts.
Your car should run out well once the suspension has been checked and refreshed.
Front shock mounts:
Yes, all these parts are in need of replacement on my ride. Pretty much everything rubber except the tires does... I am familiar with the pre-loading as well. Those are the parts I am going to gather ahead of time, while I collect more intel on my target shock/coil combo. Thanks for the brand advice.
UPDATE:
Vogtland coils have been cancelled; I already waited 3 weeks just for someone to tell me these are a 'made to order' item and it'll be another month. So, I ordered B&G Suspension S2 Sport Springs from a different source. If these are also made to order, I hope they don't also wait 3 weeks just to start making them.
I've been browsing 034. Definitely buying some of the parts for this project from there.
the current list is-
Tie rods (full bars)
Strut mounts
Control Arms w/bushings
Ball joints
End-link bushings
And of course the shocks/struts/coils.
If anyone recommends anything else be ordered for a full front-end refresh speak up. Can't think of anything else the rear would need...not much there.
Strut mounts
Ball joints
End-link bushings
David Czech
Audi A3 / S3 / RS 3
04-26-2014 04:25 AM
UrSoccer_mobileĀ®
Audi Original "S" Cars
11-08-2007 04:55 AM
