1990 90 rough idle
1990 90 rough idle
Can't keep my car running if it drops under 2500 rpm once it's warmed up. Also once it is warm it idles at 3000 rpm! Any help would be much appreciated
Unmetered error
Welcome to this forum,
Here are some things to get you going:
a,) Not immediately apparent perhaps is the huge trove of past conversations stored here which may address oft discussed common issues (such as yours) that may get you an answer faster. Always try a search of your issue using the "Search this forum" feature;
b.) Your immediate aim with your post ought to be to illicit a response, so you may have better luck if you also include detail about what you have tried already; and
c.) Here are some ideas to try - go look at this thread:
Put "Coupe dies when coming to a stop..." in the search box.
Hope this helps;
Lago
Hope this helps;
Lago
JoeCaymanBWI
02-11-2008 08:56 AM
kent@thething.org
01-01-2003 05:45 PM
