1996 Cabriolet help
1996 Cabriolet help
I have a 96 Cabriolet that is leaking hydro fluid from the convertible top motor into my trunk. Every time I get it filled, I get three cycles with the top and it is then empty. I have read you can part out the motor and fix the problem, but haven't found out where to gain the parts. Dealer wants 1K to fix or 3k to replace. Any suggestions would be great!
I have also been told by the dealer that I need a new "command and Control" module, but this is only available from Germany! Another 3k! Has anyone had to replace this?
This car was handed to me when my father past, only 28k original miles, and has been garage kept all its life! Awesome shape, except for a door ding or two. I was hoping to keep it going and hand it down to my son when he comes of age. Any help would be appreciated!
The pumps usually are fine..it is most likely a hose, "O" ring or reservoir problem. Your pump..if it is in fact bad is an old style 8 valve pump..Audi only sells the later 6 valve pump and it needs the matching control unit..big bucks.
Can you post a picture of where the pump is leaking, if possible?
Where are you in NC?
Right outside of Raleigh in a small town called Fuquay. Not sure where it is leaking, tech said lines were fine and didn't notice any fluid spray, so it must be dripping near the pump. He laid some special cloths down to try and isolate it, but the whole thing was soaked. Thinking it is the reservoir, but haven't been able to access the pump very easily to find out. Any suggestions?
The plastic tank-"O" ring is probably leaking. The tank will crack due to age. Audi has a repair kit which is surprisingly inexpensive.
Part number 8G0 898 101
About $70
The pump is fiddly to remove but the repair is straight forward. Use the correct Pentosin CHF-11F fluid in the pump.
The controller has a lot of different names. It lives behind the center of the back of the rear seat. One 8 valve controller or 8 valve pump is NLA..the controller for the 6 valve pump now. Only the 6 valve pump is available. The good news is you most likely don't need a new pump.
About $70
I had a similar leak on my '94, along with broken wires at the trunk hinge. I used the kit above and that solved my leaky pump issue. My pump reservoir wasn't cracked, so it was likely the o-ring that gave way. Be extra careful re-seating the new tank around that o-ring, even lubed up it didn't seat correctly on my first try.
Since fixing it, now I've got a slight leak from the struts on both sides onto the storage compartment cover. I'm not sure what to do about that yet...it looks like its just at the hose connection. Is there an o-ring in there or would teflon tape be a solution?
-Erick
-Erick
Mr.D-'97 A4q 12v
Mid Atlantic Discussion
11-14-2006 06:33 PM
Mister.Sir
05-12-2006 08:19 PM
S4NoRice
09-04-2003 06:17 PM
