95 A90 Quattro suspension help
i recently purchased a car, after i looked i realized the wheel was off set and after removing the strut cover i saw this, can anyone inform me on what is the failure reason and how i go about fixing this please? thank you
Audi 1995 A90 Quattro
Front suspension and wheel effected
comon problem, you can try these Strut Mount, Early Small Chassis Audi, Density Line, B2/B3/B4 Audi 80/90/Coupe Quattro, S2/RS2, UrQuattro, 4000, Coupe GT - 034-601-1001 - 034Motorsport | Performance Parts for Audi, Porsche, and Volkswagen some people have experienced failure with them
or you might be able to find some solid mounts from europe
You only need two...and you need to compress the spring too
And the hat may be still too proud above the strut tower.
polybush top mounts - Page 3 - Skoda Octavia I - BRISKODA.net
Some poly-bush conversation from over across the pond.
TOday I replaced mine strut mount with radically different thing. My friend from Bulgaria did this for me and sent it overseas. It worked on around 150 other Audis like ours
Its catted soriginal bottom of spring disc with wilder VW Golf 4 spring disc on top, using another bolt spacer and VW golf Strut mount.
The car now handles and go incredibly well. As far as I know all of the people to do this have it with no issues at all.
I costed me just under $100 with shipping included and the result is worth it )
This is the original configuration.The upper sping disk on the Golf is 22m, and the original is 13. Because of that the sping plate fits deeper in the strut. (picture 4)
would this bushing would also cause the wheel to be offset? it rubs when turning i imagine because its not connected properly it causes it to off set the wheel with weight.
