Aircon intermittent - AudiWorld Forums
Go Back   AudiWorld Forums > Audi Models > Other Audi > Audi 90 / 80 / Coupe quattro / Cabriolet Discussion
Register Forgot Password?
Aircon intermittent
LinkBack Thread Tools Search this Thread
Old 03-29-2014, 08:41 PM   #1
Default Aircon intermittent
Hi Guys,...
My air con compressor will come on every once in a while, then cut out. So I know it works, but what could be causing this?
Thanks
Tyson2busy is offline   Reply With Quote
Old 03-30-2014, 11:24 AM   #2
Quote:
Originally Posted by Tyson2busy View Post
Hi Guys,...
Thanks
Don't know what year model Audi..90..Cabriolet..but they work pretty much the same.
Could be low on refrigerant..compressor comes on and the low side pressures drop below the threshold of the low pressure switch..then the compressor kicks off..low side pressure comes back up..compressor come back on line and engages.
An over charged system will do it too. High side pressure switch kicks the compressor out when the high side pressures go up.
Some A/C gauges and an low side adapter (yellow jacket #19153 ACME FEMx13mm) on the compressor port will tell the story.
Rusty Spokes is offline   Reply With Quote
Old 03-31-2014, 02:55 PM   #3
Interesting! Wow,..talk about a complicated system!
Thanks!
Old 04-01-2014, 02:35 PM   #4
There is also a thermal switch that will shut off the compressor if ambient temperature is too cold. If you are in the north country, it may still be too cold.
hubturn is offline   Reply With Quote
Old 04-02-2014, 06:10 PM   #5
x19
What kind of refrigerant is in system R-12 or R134a?
In either way, lower refrigerant in system is doing this and check the leakage in system if you can
or let professional tech do the evacuate and recharge system with right freon gas includes leakage test. x19
x19 is offline   Reply With Quote
Old 04-05-2014, 04:27 AM   #6
Sounds low, I had the same issue.
You should run the AC in the winter once in awhile to leg the PEG oil keep the seals lubed, helps to cut down on leakage.
Evac and recharge fixed the issue.
egp320i is offline   Reply With Quote
AudiWorld
Audi R8
Paid Advertisement
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright 2014 AudiWorld.com Audi Enthusiast Community
