Audi 80 1.8S 1989: High idle and it throttles up at intervals.
Old 05-24-2015, 02:24 AM
Zhriver's Avatar
Default Audi 80 1.8S 1989: High idle and it throttles up at intervals.
Hi everyone.
I recently purchased a cheap Audi 80 1.8S automatic.
It's from 89 and only had 140K km on it and otherwise in good shape.
However it idles high, the idle will range from 1200rpm to 2000.
On rare occasions it will start throttling up and down on its own, from idle 1200 to around 2500, it stops doing this if I keep it above 4000rpm for a period.
I haven't had a computer on it yet, since none of my mechanics have one with an adapter that fits it. Also a single visit to a shop would probably run me more than what I paid for the car.
Thanks in advance everyone.
Old 05-25-2015, 12:16 PM
Rusty Spokes's Avatar
Sounds like an air leak somewhere in or about the intake manifold. Check your vacuum lines, rubber fittings and intake gaskets. You can use some Carb Cleaner as spray it on suspect locations and see if the idle changes.
Old 06-04-2015, 06:12 AM
jonas321's Avatar
Also don't overlook the rubber o-ring in the idle adjust screw. These notoriously get hard, crack, disintegrate and can cause a big unmetered air leak.
What kind of fuel injection came on that 1.8s? CIS-e? If so then I'm pretty sure there is an ISV to check too.
Old 06-05-2015, 04:10 PM
Zhriver's Avatar
Hi again everyone, thanks for the tips. I'm currently going over the things you mentioned. I'll be back once I know more.
Cheers.
dwa1971
Audi 100 / A6 (C4 Platform)
09-09-2006 01:29 PM
OMP
08-28-2006 12:02 PM
AMorris
07-15-2005 12:17 PM
geoles2
03-28-2004 10:57 PM
wahoo2.7T
02-03-2004 07:37 AM
Quick Reply: Audi 80 1.8S 1989: High idle and it throttles up at intervals.
