Go Back   AudiWorld Forums > Audi Models > Other Audi > Audi 90 / 80 / Coupe quattro / Cabriolet Discussion
Register Forgot Password?
Automatic Transmission--- Nasty Grinding Noise in Park and Neutral
LinkBack Thread Tools Search this Thread Display Modes
Old 02-24-2005, 06:29 PM   #1
New Member
Account #: 53133
Default Automatic Transmission--- Nasty Grinding Noise in Park and Neutral
My '94 90-series with 115K seems to have developed a strange problem. While stopped this afternoon I shifted from reverse to drive and briefly heard a loud grinding noise. It drove fine... without noise until I placed it in Park. The loud grinding noise is there in Park or Neutral but not while in a driving gear. The car doesn't slip gears and it shifts thru it's gears fine. My tranny fluid is clean and the level is right where it should be.
Tonight while re-testing it I noticed that my headlights diddn't work (they would if I pulled on the bright adjustment lever, but wouldn't when on hi or low beam without the lever being held). Could these be related???
Anyone have any insights to these problems?
cklanke is offline   Reply With Quote
Old 02-25-2005, 03:58 AM   #3
Tech Guru
Account #: 43812
4Driver4's Avatar
Default Is it possible that the starter is engaged? Bad ignition switch?
4Driver4
Growing old is mandatory; growing up is optional.
2005 A6 Sedan Q 3.2 (wife's whip)
2003 S8 (Q Ship)
2000 A4 Avant Q 2.8 (daily driver)
1999 BMW M Coupe (clownshoe)
1980 VW Scirocco (mid-life crisis car)
1983 Mazda RX-7 (revolutionary sports car)
1999 Mazda Miata SSB (track beotch, no plate)
2003 GMC Yukon Denali XL (the anti-earth)
2004 Dodge Dakota (hey, at least it's stick and 4x4)
4Driver4 is offline   Reply With Quote
Old 02-25-2005, 04:41 AM   #4
New Member
Account #: 88318
Default pain, hoped for somethin ....
different as a solution,you may look my post elsewhere)
juzzo
juzzo is offline   Reply With Quote
Old 02-25-2005, 09:40 AM   #5
New Member
Account #: 53133
Default Re: Is it possible that the starter is engaged? Bad ignition switch?
Nope. Not a starter grind. My car had been running for a while before the noise occured. Probably not the starter.
I can't figure out why the ignition would cause a grind... but since the headlights were affected too I had thought in that direction too.
I found an A4 post a couple of weeks ago describing the same problem (neutral and park loud grind and lack of headlights). The guy hasn't responded yet though.
Old 02-25-2005, 09:44 AM   #6
New Member
Account #: 53133
Default Re: Here's the best solution-
No... wife in med school and twin toddlers. I have done an auto to 5-speed swap before (Saab 900T) but I have neither the interest or time anymore.
Why would these problems be linked? An electrical snafu that could affect both? Could a bad torque converter cause the grind?
Still searching...
AudiWorld
Audi R8
Paid Advertisement
Tags
a4, audi, automatic, car, chevy, grinding, grinds, loud, neutral, noise, nuetral, park, put, transmission, transmisson
Trackbacks are On
Pingbacks are On
Refbacks are On
Join AudiWorld
Copyright 2014 AudiWorld.com Audi Enthusiast Community
