Can oil leak out of the intake manifold gasket?
Old 10-21-2002, 09:45 AM
Member
lskolnick(original)'s Avatar
Old 10-21-2002, 02:19 PM
ARK
ARK's Avatar
No.
Old 10-21-2002, 02:26 PM
Member
What if it does? What could that be?
Old 10-22-2002, 11:34 AM
Junior Member
Nervikterklieb's Avatar
Default time to replace the engine, but seriously...
it's porbably leaking out of your valve cover, and looks like it's coming from the intake manifold, i can not begin to explain how royally ****ed up your motor would have to be to be leaking oil from the intake
Old 10-22-2002, 01:01 PM
Member
Default That's what I thought, but...
That's what I thought. It really does look like it is coming from the intake manifold gasket though. I suppose I can start by replacing the valve cover gasket and see what happens. I degreased the engine to see get a better idea of where the oil was coming from as there was oil on both sides of the valve cover. Since then I saw no signs of a leak for three weeks but then oil started to appear around the intake manifold gasket. Is it possible that it was saturated with oil and it decided to come out? My engine seems to run perfectly. If it was so f*cked up as to have oil leaking out of the intake manifold gasket would it give some obvious signs?
Old 10-18-2014, 05:37 AM
AuudiRob's Avatar
Default same problem..
I have a leak also but I can't see it anywhere only smell it. Do I start with the valve cover also?
Old 10-18-2014, 11:20 AM
CRAZY_RUSSIAN's Avatar
and what car would that be?
Tstealth32
9
09-15-2017 04:01 AM
elijahallen
12-09-2006 09:14 AM
quattro_joe
Audi Original "S" Cars
07-18-2005 10:11 PM
Steve Balgach
11
07-17-2003 10:59 AM
scottb18
11-26-2002 07:34 PM
Quick Reply: Can oil leak out of the intake manifold gasket?
