check out my new mod guys/gals
Re: Got any spares to mail me?
fresh out. roommate and i pretty much used all we had ordered for various things. they can be had pretty cheap from the led people on ebay. just go on there and type in search.
5mm white led
then just look for the pre-wired ones as pictured in the tech article. 5mm is the ideal size. for most stuff. since the opening is big enough for a 10mm, you may try that and be fine with that instead of using two 5mm. what was nice about using two is since led's have a direct light path i could angle both in a little different direction on each side to project the light better.
5mm white led
Re: thats pretty cool without looking rice-ish. your trunk lid (underneath) is pretty clean.
thanks. I have this guy to thank.
...this is my "mentor of clean"
the judge [Bruce M.][waterwagens 2007] as you can see is trying his darndest to find a speck of grease.oil.dirt - anything but failed miserably again.
<img src="http://pictureposter.audiworld.com/61719/jeffjudged.jpg" border="4">
<b>2002 VW 337</b>
<b>2002 VW 337</b>
