IOS: 12v engine
Old 12-07-2014, 07:55 AM
goodys90's Avatar
Default IOS: 12v engine
Looking for low mileage 12v for my 93 audi 90
Old 12-07-2014, 10:12 PM
varia's Avatar
car-part.com
Old 12-09-2014, 07:45 AM
goodys90's Avatar
What engine should I go with I'm aware that if I go with afc engine that I have to have the downpipes as well. But which is the over all better engine? Aah or afc? Afc with aah cams is the way to go. I also found a set 283 cams from catcams. I also have m200 ecu. Gasket matched intake, tb gasket matched to intake, 4 to 3 wire maf conversion, with new motor will bring gasket matching intake to heads and ecm tuning by 034.
Old 12-09-2014, 07:49 AM
goodys90's Avatar
And I just found an aah engine with 87000 miles on it found an afc 73000 miles on it
Old 12-09-2014, 11:59 AM
CRAZY_RUSSIAN's Avatar
where did you find the cams?
Old 12-09-2014, 12:07 PM
goodys90's Avatar
http://www.catcams.co.uk/
Old 12-09-2014, 12:14 PM
goodys90's Avatar
Nevermind I guess they are for the 2.6l 12v are they interchangeable with the 2.8l
Old 12-09-2014, 12:41 PM
they work on the 2.8.
i thought you found some here in US
Old 12-11-2014, 12:00 PM
Baumeister's Avatar
I'll be pulling an AAH out of my '94 Cabriolet sometime before spring. 75k miles at the moment, previous owner spent about 4 grand on it mid-2013 replacing seals, timing belt, full service. I think there's a new OE oil pump in there as well.
Runs great, no leaks at all. I've got a TDI 5 speed I'll be swapping in its place.
Old 12-18-2014, 02:37 PM
goodys90's Avatar
What are you asking for it?
A4QuattroDriver
12v V6 Discussion
11
11-27-2006 02:59 PM
Greg PAW
11-27-2003 11:55 PM
Roger A. Ellis
06-06-2003 07:52 PM
adambalgach
08-06-2001 12:14 PM
Quick Reply: IOS: 12v engine
