IR key fob find and Oil pressure sensor question
Old 09-13-2015, 02:29 PM
4ringsinutah's Avatar
Default IR key fob find and Oil pressure sensor question
Hey guys, i haven't posted in a while as i have been busy with a new job promotion and a new baby, but i did want to share an awesome find with you guys. I fond a seller on Ebay that currently carries the IR key fob for our cars. They are used/cut, but i did buy one and test it out, works great! i swapped the guts into my key fob, and presto! i can now remote lock my doors! now i know these don't have great range, but if you are a purist/nostalgic guy like myself, it is a cool find. You can find this item by searching for "audi 1button fob", it should be one of the first results that pop up. They still had 4 or so when i ordered mine a few weeks ago.
As for the main reason of my post. This past week, i had a mechanic take a look at my car take care of some maintenance items, in order to get a clean look at everything, he power washed the engine. When i got it back, whenever the car goes above 2k rpms, the oil pressure light comes on, then goes away as soon as you dip below the 2k mark. Based on the fact that i did not have this issue before i took it to the mechanic, and the work he did on the car was unrelated to the oil pump or anything mechanical, i am thinking something got knocked loose when washing. I took a look under the car, and i do see a blue connector hanging near the oil filter, but i cant see where it would go. Does anyone know if this connector goes to one of the oil pressure sensors, and if so where it would be located?....also i am sure someone is going to say it, so yes, i have confirmed my oil is filled to the appropriate level.
Old 09-13-2015, 02:35 PM
there is a photo of the connector i am talking about. Based on its proximity to the oil filter housing, i am thinking this maybe went to the High pressure sensor, but i cant seem to find where it plugs in to, any ideas?
Old 09-13-2015, 03:50 PM
Rusty Spokes's Avatar
Default Not sure if your engine is an AFC..see if this helps.
Look up behind the oil filter and cooler..should be an oil pressure switch up there.
Old 09-13-2015, 03:54 PM
Head Cat Herder
Kris Hansen's Avatar
Can't be too far away.. I'd look up above where the filter is, I recall it's up and in front of the filter/cooler.
Old 09-17-2015, 04:01 PM
well ok, so i made sure that sensor is firmly connected (yes, that is the same engine config as mine, thanks for the picture!) and it is still throwing the oil pressure symbol at exaclty 2k, it does it connected or not. I read somewhere that these cars have 2 pressure switches, is there something i am missing?
Old 09-17-2015, 04:19 PM
grillage's Avatar
There are two versions of the oil pressure sensor up there. One for cars without aux gauges (the three gauge pod below the radio) that has one connection, and one for cars WITH the aux gauges that has two connections. They are both pictured below in a pic from my aux gauge retrofit thread. My photo is of an AAH engine, the one Rusty posted above is an AFC, the big difference being the place the sensor screws into
<a href="http://s146.photobucket.com/user/grillage/media/aux%20gauge%20writeup/senders.jpg.html" target="_blank"><img src="http://i146.photobucket.com/albums/r259/grillage/aux%20gauge%20writeup/senders.jpg" border="0" alt=" photo senders.jpg"/></a>
The car is wired with two wires no matter what.
I'm guessing you don't have the gauges and you have the wrong one of the two wires connected to the sensor.
More info is here on my thread...
quattroworld.com Forums: 80/90 Coupe + Cabriolet
Old 06-16-2016, 03:28 PM
CRAZY_RUSSIAN's Avatar
digging this up from the grave.
is the IR remote seller still available?
IntheQ5
Q5/SQ5 MKI (8R) Discussion
37
08-28-2023 11:37 PM
ECS Tuning-Audi
A4 (B8 Platform) Discussion
21
09-11-2021 04:04 PM
C6Silver
Q7 MK 1 Discussion
09-01-2015 08:46 PM
ECS Tuning-Audi
A4 (B7 Platform) Discussion
09-01-2015 09:16 AM
ECS Tuning-Audi
09-01-2015 08:27 AM
Quick Reply: IR key fob find and Oil pressure sensor question
